A newly granted Tesla patent combines a miniature wiper and fluid dispenser inside the camera housing — directly targeting the lens-fouling failures at the center of a federal safety investigation.
Tesla was granted U.S. Patent No. 12,636,684 on May 26, 2026, for a self-cleaning camera system that integrates a fluid dispenser and a miniature wiper blade directly into the camera housing. The timing is hard to ignore: NHTSA escalated its Full Self-Driving (FSD) — Tesla's Level 2 driver-assistance system — visibility investigation to Engineering Analysis (EA26002) in March 2026, citing camera degradation across roughly 3.2 million vehicles in sun glare, fog, and dust conditions.
What the patent actually describes
Filed in May 2025, the system goes beyond the compact spray nozzles already spotted on Cybercab prototypes in Austin. Inside a single sealed module, Tesla's design houses a small fluid reservoir, a dispensing mechanism aimed at the lens, and a miniature wiper blade driven by its own motor. According to Not a Tesla App, the wiper contours to the lens curvature — functioning much like an eyelid — rather than sweeping a flat surface. That makes the whole camera unit self-contained, with no external plumbing required.
Compared to high-pressure washer nozzles, which blast fluid and move on, the integrated wiper uses minimal liquid. That matters for robotaxi economics: a Cybercab running driverless shifts can't pull over for a camera cleaning, so reducing service intervals is a real operational advantage.
The federal investigation driving urgency
NHTSA's upgrade to Engineering Analysis — per Electrek (NHTSA EA26002) — is a significant step. It means regulators found enough evidence of a safety pattern to justify deeper scrutiny before deciding whether to demand a recall. The agency specifically flagged camera-blind incidents caused by environmental fouling: dust storms, low-angle sun, heavy fog. That's the exact failure mode this patent is designed to prevent.
Limits and open questions
The cleaning system won't fix every FSD camera problem. Sun glare and harsh contrast lighting — also cited in the NHTSA investigation — are optical issues no wiper can address. The module is also larger than standard camera units, which may prevent retrofitting onto existing Model 3 or Model Y vehicles without body design changes. Tesla has not announced a production timeline, and the patent covers the Cybercab robotaxi and Optimus humanoid robot platforms first. There is no confirmed rollout date for consumer models.
Moving parts and an onboard fluid system add manufacturing complexity and cost — trade-offs Tesla will need to weigh against the pressure building from federal regulators.
Tags: Tesla
Ura_polakov
Iurii Poliakov
37 years (20 years driving)
